engine missfire
boostedmini
engine missfire
Post by boostedmini »
Hi Guys,
My mini (1.3 turbo setup) had a bit of a missfire even under light throttle but when RPM got to about 3,000 the ignition would just drop out and the tacho would read 0.
I worked out the VR sensor was too far away from the trigger wheel and then the rpm was fast enough the sensor was not getting a clear pulse.
does anyone know when the spec should be for the air gap of the VR sensor to the trigger wheel?
Grant
Hi Grant,
1mm is the typical recommended spacing.
cng1
Post by cng1 »
Personally on a mini-sized trigger wheel I would advise a little closer 0.75-1mm - closer never hurts but beyond 1mm is where you start getting problems. On larger trigger wheels I still advise 0.75-1mm but below 5" you need to rapidly decrease the gap. For instance on a 2.5" wheel I reccommend a 0.25mm air gap.
www.trigger-wheels.com
