Megajolt in a 91 Firebird Formula
Redbird
Post by Redbird »
I cant believe I never posted up after I finished my install, so here it is:
First I converted a distributor to use as a trigger, figuring I would eventually mount a proper trigger on the crank which I never got around to. Image
Otherwise install and tuning went quite smooth, factory computer handled the fuel injection, megajolt handled the spark. The system worked flawlessly from day one. Engine is a chevy 350 running a T70 turbo at about 12psi boost. Image Maxed out the injectors so tuning stopped from there...
That's awesome! Thank you for sharing.
We need more muscle cars running Megajolt! Spread the word on the forums on what you did! :D
