Load value V4 in test mode
Alex B
Post by Alex B »
I have the Megajolt assembled and connected to the laptop. What pressure should the Load sensor show when nothing else is connected? It reads now 44 KPa. When I suck the MAP sensor it gets down to 0, it will even get as low that the needle overshoots 0 and ends up at the 102 mark (it's in NA-mode). When I blow I can increase pressure up to 56 KPa, then my lips give in and I get pressure loss, resulting in revolting noises :wink: . The domestic barometer shows 1010 (millibar?), being almost 76 something, I have no idea to what kind of scale that is connected. Is the reading of 44 KPa from the MAP sensor a normal value in room conditions? The needle shows occasionally a short and quick movement to almost 60 KPa before getting to rest again at 44.
Tia,
Alex
Alex B
Post by Alex B »
Anyone? Brent?
Hi Alex, sorry for the late reply. When you say "assembled" do you mean you soldered together one of the older V4 kits?
Alex B
Post by Alex B »
Hi Brent,
It's a Rev C that was auctioned on Ebay. It was completely untouched, all parts in its original packing. I downloaded the 4.0.2 version of the Configuration/Tuning software. I haven't downloaded the Controler Firmware; is that needed?
Alex
