Analog input (i need help)
sim_ou_nao
Post by sim_ou_nao »
i want to connect my wideband to my megajolt, ido what the guide say
but i still have 5v between this 2 points
this is ok, or a i do something wrong?
Pedro Silva
sim_ou_nao
can anyone help me?
Pedro Silva
toenee
Post by toenee »
I'm sure someone will be along soon, but just so you know your not alone, I've also held off doing this to mine, as I also didn't think the instruction was very clear.
Apologies for the late reply.
There might be a trace voltage remaining that you are measuring sourced from the processor. If you cannot measure any conductivity between the solder pad of R6 and the opposite side of where you cut, you should be OK.
Then, you should be able to connect the wideband to your megajolt and measure a value on the aux input.
sim_ou_nao
Thank you for the reply toenee and brentp
brentp, can i take out the resistor?
Pedro Silva
Absolutely; you can take out the reistor as well. If the resistor is gone and you still measure 5v, I would not worry about it as it is likely stray capacitance or a weak pull-up on the microcontroller.
Alex B
Post by Alex B »
Out of sheer interest, what are you aiming at with connecting a wideband? Advance correction based on the wideband's readings?
Alex
sim_ou_nao
no Alex, it´s only to help me tune my carb/needle (hif44).
Pedro Silva
Keep us posted on how it's working!
sim_ou_nao
now i have 4 volt :roll:
Pedro Silva
Keep us posed, and let us know what kind of readings you get after you connect your wideband system.
sim_ou_nao
Short test, with sucess :)
Now i have to find the misfire :cry:
Pedro Silva
