only running on 3 cylinders, classic mini
panch1989
Post by panch1989 »
I've got a 1293 turbo with a 266 cam, running a freshly installed megajolt. Loaded with map21 from the directory.
I noticed that it was misfiring today and wouldn't go past 3k when rev ing. I pulled out the plugs one by one to see a change in revs and when removing the 3rd cylinder it didn't change. I changed plugs and leads on this and still not firing. Does anyone have any ideas on what it could be?
Alex B
Post by Alex B »
Does the plug give a spark when you have it out of the engine block and have it earthed?
Alex
panch1989
Post by panch1989 »
Yeah it does.
Alex B
Post by Alex B »
How about compression? Valves in good working order?
Alex
panch1989
Post by panch1989 »
I'm waiting on a compression tester this weekend, will come back with results then.
Did you discover anything interesting?
