Getting laps to show up in GEMS project explorer
cooper2006
Post by cooper2006 »
I am using the Perl script to convert the log files to stf files, and the individual laps are not showing up in the GEMS project explorer window. Has anyone else had this problem? Is there something special that you have to do prior to loading the files to GEMS, or is there some configuration in GEMS to make this work that I am not doing?
Olaaf
Post by Olaaf »
I have the same issue, only 1 large lap is shown and i don't see a way to set a marker... any ideas?
PS14
Post by PS14 »
Did you add a lap or split beacon to your map? Heres a link to the gems forum topic on the subject:
http://www.gems.co.uk/gemsforum/viewtopic.php?f=5&t=707
Olaaf
Post by Olaaf »
Yeah, i followed the instructions, but no luck.. i've attached a screengrab of the error code..
MikeD
Post by MikeD »
Can you attach your log file (the final stf file for the GEMS and maybe also the base csv file)?
Olaaf
Post by Olaaf »
Yes, thanks very much- log files (4 files, from each step of the process) are here for download:
http://www.flyingratms.com/downloads
note, the base log file for thunderhill came from viewtopic.php?t=3696
Olaaf
Post by Olaaf »
Has anybody been able to get a log file from RCP into Gems with laps? could you post it? This is my only hurdle from making the jump back into RCP- real analysis software support.
PS14
Post by PS14 »
Olaaf, I got one I can post later tonight, when I get home from work. I played with the thunder hill file a little. what were your lap times? were they around 2min15sec ? Dave
Olaaf
Post by Olaaf »
OK, thanks. I don't know the laptimes- it's not my file, just a sample log i downloaded from AutosportLabs dropbox sample log folder.. 2:15 sounds right for Thunderhill, though.
PS14
Post by PS14 »
ok so i uploaded a zip file to my google drive and included a shared link below. so you should be able to download it. it has my log file and template. i use the GEMS software from AEM. i cant remember if this log was one were i told RCP the start/finish line or not. but you can see the "line" of all 12 laps, but the times are not acurrate. i think thats because its a 4/10 oval and gps timing is to far off. but you can see were i have things set in the template. hope it helps.
https://drive.google.com/file/d/0B2i_k4 ... sp=sharing
Olaaf
Post by Olaaf »
OK, thanks! finally figured it out, it was an issue with setting the lap beacon range and time window to sometime much smaller (the defaults overlapped the entire range of the log file). still need to work on adding the beacon at the exact start/finish line, but will work through that.
