4 AnalogX on the same CAN bus
Vrushabh
Post by Vrushabh »
Jumpers on AnalogX lets you configure 4 AnalogX devices to run on the same CAN bus, agreed but I am confused which jumper you are talking about because the documentation for AnalogX does not specify some thing specific for 4 AnalogX together. Also how will we obtain CAN ID for each AnalogX input.
It is documented here:
https://wiki.autosportlabs.com/AnalogX#CAN_base_ID
The jumpers are on the bottom of the AnalogX board, and are labeled accordingly.
Hope this helps!
Vrushabh
Post by Vrushabh »
Is it possible to use 3 AnalogX on same CAN bus or it should be a pair of 4 ? Does it affect us in any case because 3 AnalogX will serve the purpose for me.
Thank you.
You can use 1,2,3 or 4 AnalogX on the same CAN bus, by changing the jumper settings, documented in the WiKi.
