LPG safety switch needs tach input ..MJ have an output?
EA82GT
Post by EA82GT »
I run LPG/ Propane. It employs a safety switch that is triggered by an input from the single coil on the car's 80's coil and dizzy set-up.
I need to take a better look at all the MJ has to offer, but thought I might take a short cut and ask here.
Is there an equivalent output of the MJ that will excite the safety device simply looking for a tach signal just to tell it engine is running. When no engine running input, safety switch shuts off the gas supply
thanks
Re: LPG safety switch needs tach input ..MJ have an output?
Hi - You can possibly use one of the GPIOs to trigger it, and set it to be on or off at a specific RPM threshold.
EA82GT
Post by EA82GT »
OK thanks for that info to research. Meanwhile, I bought a coil adapter [diode set I guess] for running a standard tacho off coil pack so this should do the trick for starters
