Screen Wiring
niduncan
Screen Wiring
Post by niduncan »
The <a href="http://picasso.org/mjlj/?q=node/606"> Installation Diagram </a> shows that the screening for the VR sensor and PIP/SAW are connected to pin 7 of the EDIS module AND TO EARTH. Reading the other forums indicates that pin 7 should not go to earth as it can stop the advance working.
Which is correct?
Nigel.
Kenn
diagram
Post by Kenn »
if followed the the diagram to the letter (apart from the wire numbers on the coil pack plug) and everything works as it should.
