shift light megajolt jnr
jimbo198966
Post by jimbo198966 »
hi,
how do i go about putting a shift light onto my megajolt jnr?
i've read the guide on here, but can't understand it :(
thanks, jimmy
Here's the section in the installation guide that talks about installing a shift light:
http://www.autosportlabs.net/MJLJ_V4_ve ... hift_Light
Let us know if you have any specific questions!
jimbo198966
brentp wrote:Here's the section in the installation guide that talks about installing a shift light:
firstly, thanks for the reply :D
Thats the guide i've been looking at...
i just can't get my head round, on how to wire just a single shift light up.
do i have to 'set' it via the megajolt software?
cheers, jimmy
ps i'm totally new to this megajolt/eletronic ignition lark! :shock:
spandit
Post by spandit »
From what I understand, you wire a single shift light up as follows:
1) connect one end to a 12V source
2) connect the other end to the dedicated shift light pin on the MJLJ connector
3) set the shift light RPM in the software and flash to the controller
jimbo198966
spandit wrote:From what I understand, you wire a single shift light up as follows:
ahh thats where i'm going wrong then :roll:
done, 1) + 2)
Just need to set the shift light RPM. :)
Are there any guides for that? :lol:
spandit
Post by spandit »
It's easy - on the ignition map page (the table of numbers) there are 3 tabs. Haven't got it in front of me but click one of them and there is a box clearly marked to set the shift light and limit RPMs
jimbo198966
spandit wrote:It's easy - on the ignition map page (the table of numbers) there are 3 tabs. Haven't got it in front of me but click one of them and there is a box clearly marked to set the shift light and limit RPMs
ahh nice one, found it, just need to plug it in, and check what mine is. haven't got the lead or car with me :cry:
cheers pal, very helpful guys!
:D
Jimmy
jimbo198966
it now works :D
i had wired it up wrong too, and the rpm was set at 7000, now at 6000, but i'm going to lower it again :D
thanks alot for your help guys :D
