MJLJ Stimulator...with some pics
MartinM
Post by MartinM »
Here's something I knocked up for fun - just connect +12v to the connector near the Molex, the Molex into the MJLJ and the computer to the MJLJ and the rest should be self-explanatory from the picture!
Only components are the LEDs, some series resistors and an Atmel AVR (ATTiny13 - about GBP0.75) with about 75 lines of assembly code....
Looks neat! I'll post pics of mine, but yours wins in sophistication, I only used a 555 timer to stimulate PIP. :wink:
I'm also building a new test bench for more elaborate testing, I'll post pictures of that as well!
MartinM
Post by MartinM »
I used software so that I could get the rpm (500-8500) to be linear with the pot rotation - the ATTiny13 has an onboard ADC, so I thought I might as well use it!
It's not really a test bench, since it doesn't take any notice of PIP - that's the MkII version I suppose
It also, obviously, only does Engine Load as TPS - I still have my trusty syringe and windscreen washer pipe for MAP :)
No kidding on the non-linearity! the last few 1000 RPMs are a bit touchy!
I've attached pictures of my abomination :D it's not pretty but it does the job. The MJLJ unit it's attached to is the grandpappy first MJLJ v2.0.
You know what works great for testing the map sensor? One of those rubber bulbs used for clearing an infant's nose. Cleaned, of course. :D
stimulator closeup
stimulator closeup
stimulator
stimulator
Spockie-Tech
Post by Spockie-Tech »
Hi Martin
I relaise this is an old thread, but I have just completed two Megajolt/EDIS's, and am interested in the source code to your driver micro if you will share it.
I have AVR programming facilities, and even a ATTiny on the shelf !, so is you code and a diagram available please ?
regards
Brett
MartinM
Post by MartinM »
Hi Brett
AVR Studio 4 files attached. Enjoy!
Any questions, just ask - post here or PM.
Let me know if they make sense - if so, I'll post the schematic ....
Regards
Martin
MJLJStimulator.zip
MJLJ Stimulator V1.0
(16.1 KiB) Downloaded 1201 times
Spockie-Tech
Thank you very much Martin !
Got them open in AVR Studio and perusing them now.
AVR Assembly code is new to me ( did some 90s1200 code a few years ago), but I've done plenty of coding on Pics, Z8's, 68x and so on, they're all similair, so its looking straight forward enough.
get an ADC input, use that as an offset into a lookup table to compare against an interrupt driven counter. nicely formatted :)
I've been meaning to get into some AVR coding for a while (I have a Mega32 and 90Can128 on the bench here to do some Can/Lin bus projects for my car as well a Megajolt)) - so this is a good excuse to get moving on it
Now I need to do some datasheet browsing - The Tiny I have is a 15L - I have to see what the difference between that an the 13 is.
If you have a schematic handy that would be useful, but with only 8 pins, I'm sure I can figure it out if its not convenient.
Has anyone thought of adding a temperature input to the MJLJ ?
I was thinking of analog tweaking the Map input with a coolant sensor modifier so as to pull the advance back a bit on hot days without having to mess up the existing code or configurator.
jonboylaw
Circuit diagram please :)
Post by jonboylaw »
I also would welcome a circuit diagram.
Jon
MartinM
Post by MartinM »
Sorry chaps - completely forgot :(
Here's a very badly laid out schematic on a scrappy piece of paper inelegantly scanned...
jonboylaw
Post by jonboylaw »
Cheers Martin
:D :D
