Last quick question. MAP/TPS.
I have the Map MJL, is the below pic correct (in realation to the power and negative which replaces the TPS) or does the TPS points stay blank(empty)?
Rob
Rob
- molex_wiringcolour_1248.jpg (25.48 KiB) Viewed 20671 times
Were you just looking for the correct pinouts, or are you planning on doing any mods the the board, or convert it to TPS?
Here's the official pinout for the unit (your image shows a V2.X board - is that what you have??)
taken from here:
http://www.autosportlabs.net/V2_Build_a ... tion_guide
taken from here:
No - not correct.
Only connect ground to the upper right and +12v to the lower right.
Leaves the others unconnected for a MAP installation
(it actually won't do any harm I believe (seeing that the TPS option components aren't installed), but if anyone connected a TPS MJLJ into your plug, smoke would be let out...)
Brent one last quickie!!
http://www.autosportlabs.net/MJLJ_V3_ve ... g_the_MJLJ
In relation to the diagram,,, USER OUT 1 AND THE 12v+ are they constant live? or switched ignition.
Thanks again
Rob
Thanks again
Rob
Brent,
I have had a busy day today, I got the Crank pulley off and the 36-1 wheel fitted, the sensor bracket fabricated and fitted.
The system was set up and tested. I have not been able to get the unit sparking?
Two quick questions, how close does the sendor have to be to the wheel?
Does the ignition unit it'self need earthing?
Rob
Rob
