it just occured to me that if the tps uses a voltage input then if using a map sensor you could still
use the tps input, except connect a lamda sensor to the tps side ?? just software select a different calibration table ?
after all the lamda just outputs a voltage . right ?
this would mean you could realtime adjust your mixture too
im an electronics moron so flame away tell me why you cant do this ?
it just seemed like a good idea at the time..
P.S if it is a good idea can you send me one for free for the idea ? heheheh...
richard
